Huginn Kenningar
Flight distance : 49635259 ft
I FCC mode the Pro controller has 2W of power while the standard controller has "only" 0.4W.
The Mavic 3 in FCC transmit at 2W (O3+) so with the standard controller you have 2W on the drone and 0.4W in the controller but with the pro controller you have 2W on both sides, so communication will be better.
Apart from that, antennas on the pro controller are bigger, so will receive the signal a bit better.
On the other hand in CE mode both the drone and the controller are limited to 0.1W in 2.4Ghz and only 0.025W (yep, a joke) in 5.8Ghz, so unless you use the FCC mod, which is 100% recommendable, the performance will be the same on both controllers (except for the bigger antenna, which at that power will give an insignificant boost).
PS: Sorry, thought was about the M3; the Air2S uses O3, it works at 1W in FCC so when paired with the standard controller (0.4W) isn't delivering it's full potential. It will also benefit from the increased transmission power of the pro controller and the bigger antennas for reception.
I'm also interested in the pro controller just to get the 2W transmission, but at this point is too expensive for me so I'm flying with the standard controller and the FCC mod wich is already a blast with the M3.
