Huginn Kenningar
Flight distance : 49635259 ft
KLRSKIR Posted at 9-5 11:08
The majority of users buying this aircraft will be flying WELL within 1km, FCC or CE. Range truly shouldn't even be a consideration IF using this drone for what it is intended.
There's no way you are flying 1Km in CE at low altitude, you won't get past 100-200m at 5.8GHz 0.025W before total disconnection if you are flying this drone how it's intended; at low altitude/interiores/walls/trees/obstacles inbetween.
Usable range of the Avata in Europe is 50 to 100 meters (a joke). And you'll get plenty of shadow areas, disconnections, input lag, low bitrate, etc.
At high altitude unobstructed LOS and pointing the controller towards the drone you could hit 2Km easily, but that's not how this drone is intended to be flown, and even though, a single obstacle like a tree or someone passing before you, will kill the connection as 0.025W give no signal penetration at all.
So in resume, you must hack it to get the 5.8GHz at 2W or just return it to the dealer. |
