best settings for night shots - aurora borealis
6690 27 2022-9-5
bxq
Flight distance : 3139314 ft
Poland
soo seems that last two nights were awesome in terms of air quality / no clouds / moon hiden and high aurora activity - went out yestarday to take a try on it and thought i had nothing [not visible on dji rc live feed] but one of 180 panoramas got something - on the right of the picturte at horizon line, all i did was pump EV to max
Q: what can i do, maybe in manual settings to get even better picture of aurora
picture, sadly forum has 2 MB limit so i had to compress it from 8,57MB
2022-9-5
Mavic57pro2
Flight distance : 3772247 ft
I took this with a dslr, ISO 1000, aperture 2.8, shutter speed 5 seconds.
You just have to experiment. One tip its quite often larger than you can see with a naked eye, however with the right settings you capture more than your eyes can see.
2022-9-5
bxq
Poland
Mavic57pro2 Posted at 9-5 09:36
i do not expect miracles as i am taking pictures from norther Poland - just want to squeeze as much of it as possible while it's possible - thanks will try
2022-9-5
fateofangel
Flight distance : 1397238 ft
Poland
nice man
2022-9-5
CloudVisual
Flight distance : 97545420 ft
Drones really aren't designed to capture very long (5+second) exposure shots.
If you own a ground camera, grab a tripod for it and you'll be able to get some amazing shots from the ground, with great results.
2022-9-5
juan55
Flight distance : 577096 ft
First you must move to a location with poor or none light contamination of a city ... aka .... no lamp lights
The Mini 3 Pro has a fixed and luminous diaphragm f/1.7 …. After review some videos, I suggest ISO 1600 (max suggested)  and manually try to find out with shutter speed is better.
As first try, I suggest you to check camera settings with the drone static, without fly. Once you have the settings, then you can think about to fly. Video probably should be better as is 25/30 FPS an the image integration is more visible. If the Aurora is not strong, probably you need to get up ISO to 3200 but there will be noise. Good luck.
Next month I am traveling to Iceland with the aim to get some ones with the drone.
2022-9-5
DJI Paladin
Flight distance : 318 ft
Hi there. Hope that you could get the best recommendation from our fellow DJI Pilots. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support!
2022-9-5
Montfrooij
Flight distance : 2560453 ft
It will be hard to capture with a tiny sensor camera that is flying since you will need to bump the ISO and use long shutterspeeds.
2022-9-5
DAFlys
Bodkins Best Photography Posted at 9-5 12:36
Unless you're super far north or getting an extreme storm you're not likely to get much from a drone.  Stability is an issue.  Things likely won't be sharp with all that drift during a 4+ second exposure.
Stability and longer shutter speeds are key.
Great Shot
2022-9-6
hallmark007
Flight distance : 9827923 ft
You don’t need to shoot any higher than 5/8 seconds with wide open Aperture and ISO as low as you can get, but you need to own a mavic 3 for this , all you can do with mini 3 is shoot lowest shutter speed lowest ISO…
2022-9-6
FPVin
Flight distance : 300502 ft
Cool shots!
2022-9-6
Bussty
Flight distance : 320951 ft
New Zealand
Anybody tried multiple 2 second exposures with the Mini 3 Pro and stacking together using the additive blend mode?
2022-9-6
ElleKN
Flight distance : 755669 ft
Nice night shot. The tips are already written, so there is nothing else to say for me:-)
2022-9-6
ElleKN
beautiful shot. thanks for sharing
2022-9-6
ElleKN
That is definitly an amazing picture. Just wow - congratulations for it!
2022-9-6
juan55
https://forum.dji.com/forum.php? ... D776%26typeid%3D776
It looks like stability by night is an additional problem
2022-9-6
Beta5K
Flight distance : 196880 ft
Going to a place with less light pollution would definitely help.
2022-9-6
GeirB
Flight distance : 290335 ft
Norway
This photo was shot with the Mini 3 Pro this Sunday. I used a 2 second shutter and ISO 1600 for this. Also, you will have to shoot in RAW and process it in Lightroom (or similar) to really pull detail out of it.
This was my first test of shooting the Aurora with a drone, I'm impressed at least The F1.7 lens really helps.
Edit: Note that the Aurora activity wasn't really at its highest when I captured this.
2022-9-6
bxq
Poland
hey, thanks and amazing view
2022-9-6
scottfrey
Bussty Posted at 9-6 02:15
Here was my first test shot (don't mind the horrid wildfire smoke and the quarter moon in the shot) 14 two-second exposures, stacked.
2022-9-6
Labroides
Flight distance : 9991457 ft
Wideangle lenses make distant things look even further away.
Unless you have the aurora showing over a large part of your sky, the Mini 3 isn't going to get anything worth the effort.
2022-9-6
Bussty
New Zealand
Labroides Posted at 9-6 13:50
This is true but sometimes it won't be wide enough. This is a 17mm in Queenstown, little old NZ.  Very rare though to be this far North and this big. You would have probably even seen this one in OZ!
2022-9-6
ArcticPhoto
Norway
To "freeze" the movement of the auroras you need as short shutter speed as possible, preferrably less than 8 seconds. That means wide open aperture and high ISO. If the auroras are moving fast and you use a too long shutter speed it will all become a blur.
I always use a wide angle lens, between 14 and 24mm. Where I live the auroras cover large parts of the sky during powerful outbursts. It is also a good idea to include the landscape, that gives depth and a stronger visual impact.
This photo of a very fast moving aurora (almost like an explosion) was taken with a 14mm lens, 5 sec. exposure, f/3.5, ISO 2200 with a Nikon full-frame camera.
2022-9-6
Bussty
New Zealand
ArcticPhoto Posted at 9-6 14:12
That is incredible!!
2022-9-6
Bussty
New Zealand
scottfrey Posted at 9-6 13:04
[view_image]
Good to know that works. Thanks
2022-9-6
Bussty
New Zealand
GeirB Posted at 9-6 08:09
Good to know. Says in a really major Aurora the Mini 3 Pro might just be able to generate a reasonable result.
2022-9-6
RoZis
Flight distance : 1423173 ft
To what extent are solar storms able to distort the GPS signal and maybe the wobbling is also a result of the magnetic activity.
Is the Mini 3 Pro night stable when the kp index e.g. is less than 3?
2022-9-6
ArcticPhoto
Norway
RoZis Posted at 9-6 23:29
GNSS satellites are protected to a certain extent, but a very strong solar storm may distort them temporarily. More info here: https://breakingdefense.com/2022 ... dio-communications/
In October 2003 was the most powerful solar storm in recent decades. From NASA website: "Thirteen years ago, a series of large solar storms began to rage above the sun’s surface. including the largest solar flare ever recorded, measuring a whopping X-28—where X class flares are the most powerful flares and the number afterwards represents additional steps in strength. Because this event occurred around Halloween, these storms were dubbed the Halloween Storms".
Magnetic compasses can also be affected during powerful solar storms.
Here is a link: https://www.nasa.gov/feature/rem ... olar-storms-of-2003
2022-9-7
