First flight Frustration
1044 8 2022-9-9
Chrislayeruk
Flight distance : 96811 ft
Hi again, my inaugural flight has been postpones as the Mini Pro 3 will not allow me to take off.
Code 30064
also orange code 180059.
The Obstacle avoidance is set to bypass and I have rebooted controller and aircraft a couple of times to no effect.
any advice would be appreciated, not the start of my drone journey I was hoping for.
thank you in advance.I understand others are having the same issue and look forward to a quick solution... Chris
2022-9-9
Andreja
Flight distance : 1085302 ft
Do you have a description of the code 180058? I can't find anything on the Internet about it.
For the vision sensors (usually code 180059), that's normal. They first turn on once you take off.
2022-9-9
Chrislayeruk
Andreja Posted at 9-9 09:28
My mistake there. it’s says, in Orange, Aircraft not in flight, Vision systems and obstacle avoidance disabled… Code 180059. I’ll correct my original post. It still won’t fly though.
2022-9-9
DowntownRDB
Flight distance : 1722 ft
There are 3 or 4 other threads about this same issue.  A DJI Administrator reponse can be found here.  Hope this helps.
2022-9-9
Flormo2002
Flight distance : 13686729 ft
Chrislayeruk Posted at 9-9 10:00
Seems like DJI is having some quality control issues lately. I shouldn't put it out in the Universe, but my Mini 3 Pro seems to b e doing okay except for long distance range issues but don't generally go out further than 1/2 mile anyway
2022-9-9
DJI Stephen
Hello there Chrislayeruk. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try to uninstall an reinstall the DJI Fly application ( https://www.dji.com/dji-fly ) to see if the issue will still persist? If the issue still persists, it would be best to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this matter. We will do our best to help you and give out the best resolution for the said issue. Again, I am sorry and thank you.
2022-9-9
Chrislayeruk
DJI Stephen Posted at 9-9 19:37
Thanks for the reply, I have already reloaded the firmware, as advised, in aircraft and controller to fix an earlier issue.
I have the stand alone remote, so not sure how to replace software in that. I also notice there are others with the exact same issue and a firmware update is on the cards.
The fact there is no time frame for this is understandable but frustrating as I have paid a lot of money for an up to date, highly regarded drone that I have never been able to fly. Still, life’s a long song, as the song says…
2022-9-9
Chrislayeruk
Chrislayeruk Posted at 9-9 22:49
New firmware and my Mini 3 Pro flies… It was great to be able to finally fly the aircraft.
2022-9-11
Chrislayeruk
The Beta firmware I was supplied has solved my problem. I was able to fly..
2022-9-11
