Propulsion error message during Avata maiden flight
2807 11 2022-9-10
fansfa6c284f
Flight distance : 7195 ft
Singapore
I recently have the opportunity to maiden my new avata drone. Did both compass and IMU calibration before flight . Flight was successful but on a few occasions i received a propulsion error message during flight. It does not affect the flight but it gave me less confidence to continue flying with this message. Below is the link to the goggles 2 video of the maiden flight. Much appreciate if anyone  can help to resolve this.
https://youtu.be/dJKIgf9RLxY
2022-9-10
chillibadger
Flight distance : 233064 ft
Mod can you move this to Avata section?  2nd post on Avata I've seen here in so many days
2022-9-11
Bigplumbs
Flight distance : 620164 ft
Best to embed videos like this
2022-9-11
DJI Stephen
Hello there. Good day and thank you for reaching out. Kindly please keep us posted if the issue still persist and affects your DJI Avata's future flight for us to be able to assist you. Thank you and kindly please keep us posted.
2022-9-11
fansfa6c284f
Singapore
Bigplumbs Posted at 9-11 01:40
Thanks for sharing. Will keep that in mind when i update on the issue at hand
2022-9-11
djiuser_4fWPmyjK4xhR
Flight distance : 851624 ft
Venezuela
Hi, did you try to use turtle mode to see if the motors are running? im having the same issue rn and i dont know what to do in turtle mode only the backwards motors are moving, however every time i start the  avata it moves every propeller
2022-10-10
Venezuela
2022-10-10
evcf05
Venezuela
2022-10-10
fansfa6c284f
Singapore
evcf05 Posted at 10-10 15:12
I still see the propulsion system error message on and off during flights. It does not impact my flights at this moment in time and I have no issue activating turtle mode when the avata was down in a position to flip over.
2022-10-11
djiuser_pg7FCq5Ezji6
Flight distance : 260997 ft
Brazil
Hello everyone. I’m from Brasil and I have the same problem. In my case it only appears when I'm in manual mode. My first 2 flights were perfect without any notification. From the third flight it started with these error messages. Has anyone ever contacted dji to find out what they say about the subject?
2022-10-27
HDPS
Flight distance : 44957 ft
Brazil
make sure all propellers are tight in place, that would be my first check
2022-10-27
FPVTrendz
Flight distance : 1241020 ft
All good advice here but also, check that your battery connection is working. Some people are starting to have issues with one of the prongs in the back of the avata where the battery plugs in, being pushed back inside it and causing the battery to stop making its connection on the metered part of the battery. Then it gives the propulsion error message. I have not had this happen to me, but I have seen others comment on it, so just something to check. Of course, if this is the issue, the only solution is to return it to DJI for warranty repair.
One other thing you might check, which this is probably not what's causing it, but take your props off and make sure there is no grass or weeds wrapped around the motors. When I changed my props, I found a ton (yes a ton lol) of grass and weeks wrapped around the motors that I removed. It reminded me of a weed eater how grass wraps around it lol.
2022-10-28
