Grant Brown
![](https://forum44.djicdn.com/data/attachment/common/c2/common_12_usergroup_icon.png) lvl.3
Flight distance : 110515 ft
South Africa
DJI Stephen Posted at 9-11 23:15
Hello there Grant Brown. Thank you for reaching out and for giving out these information. may we please know if you are receiving any error message or error codes on the DJI Fly application? For reference, in Normal or Sports Mode, when the Downward Vision System us unavailable or disabled when the GNSS signal is weak or the compass experiences interference, the DJI Avata cannot position itself or brake automatically, which increases the risk of potential flight hazards. At this time, the DJI Drone may be more easily affected by its surroundings. Environmental factors such as wind can result in horizontal shifting, which may present hazards, especially when flying on confined spaces. Thank you.
Hi Stephen. There are no warnings aside from the alert of being low to the ground. When flying the Avata with a motion controller do the downward sensors try to keep a set height above the ground in both Normal and Sport mode? It may be that when encountering the chair leg/cross brace (in this example) the Avata assumes this is the ground (or an obstacle) and attempts to raise the drone to the set height and at this point it will happen to hit the bottom of the chair seat, when it hits the top of the seat its lift is restricted and so it adds more power to try overcome the restriction to get to its set height from the sensor? |
