Mavic 2 Pro remote ID
5370 21 2022-9-13
Harbor Pictures Company
Flight distance : 693035 ft
All,
Any news on if there is a solution for Mavic 2 models to be remote ID compliant? As one who is still using mine professionally, I hope there is. Any planned hardware upgrade to the Mavic 3 on my end would be later than this fall when this is supposed to be implemented.
Thanks!
2022-9-13
TonyPHX
Flight distance : 11229610 ft
I was thinking the same @Harbor Pictures.  M2P is the moneymaker out there.  If it ends up taking a module, then I'm willing to do it, but first would be nice to see this retroactively added (if possible) as a software feature.
2022-9-13
TonyPHX Posted at 9-13 08:40
Let’s hope the engineers come up with a good solution, and not be forced into an equipment upgrade.
2022-9-13
TonyPHX
There really is no replacement to the M2P currently.  It's likely gonna be a RID module to stick on top of the M2P.  : (
2022-9-13
Mobilehomer
Flight distance : 18135846 ft
You really need to do research into RID. If it is not built into the drone, then you must use an exernal module. The basic information is out there. At this time, the FAA specifications have not been finalized. It goes into effect September, 2023.
2022-9-13
Mobilehomer Posted at 9-13 10:08
Guess when I read about it I saw it was pushed back. I read it in error as being in this year - '22. So much for reading on my iphone. Appreciate the clarification!
2022-9-13
Mobilehomer
Harbor Pictures Company Posted at 9-13 10:15
Compliance deadline has been moved to December 2022. Implementation is next year. The compliance list is very short right now.
https://uasdoc.faa.gov/listDocs
2022-9-13
Mobilehomer Posted at 9-13 10:34
Ahh - it was '22. I missed the word "compliance" then. Feel a little better now.
Appreciate the update. I'll keep a better eye on things and know that there's the better part of a year to sort all this out.
2022-9-13
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. I will be posting a link wherein you can check all the details with regard to the Remote ID. Hope this helps. Thank you for your valued support.
https://viewpoints.dji.com/blog/ ... -and-your-dji-drone
2022-9-13
TonyPHX
Research done.  : )
Now the question becomes, can an existing drone be made to be compatible.  Thus, this line of thought.
2022-9-13
TonyPHX
DJI Paladin Posted at 9-13 19:08
Looking forward to your blog post on the subject!
2022-9-13
Mobilehomer
TonyPHX Posted at 9-13 19:51
Research done.  : )
Check the link in reply #7 The Mavic 3, Mini 3, Air 2S are all compliant. But if they are not on the list, they will need the external module. DJI has also stated that many of their existing drones and all their new releases will be compliant with a firmware update.
2022-9-14
TonyPHX
Yep, saw that.  Still wondering if a classic drone like the M2P could be updated to be RID compliant.  I am guessing there is not a lot of will from DJI to consider that, but given the SDR components already inside, I am thinking there is a way.
2022-9-14
DJI Paladin
TonyPHX Posted at 9-13 19:52
Thank you for your continued support, Tony and happy flying always!
2022-9-19
Michael Hughes
So I guess if government come out with new rules for equipment then said business equipment is obsolete and a complete right off.
Or loss caused by the government.
Tax advice ?
To hell with buying a 300$ RID module to tape to top of drone.
If it was 50 or less it might be worth it.
Time to put a 4 Sale sine on M2P and Phantoms
2023-3-21
Mr. Strat
Flight distance : 4542854 ft
Michael Hughes Posted at 3-21 13:56
Tax advice ?
It's only March. The RID requirement is still six months away. I'm sure there will be more affordable solutions coming along.
2023-3-21
djiuser_0BrFdiwdnEdm
Flight distance : 237766 ft
Just wondering if there is an update on the M2P getting a firmware update for the RID? I saw that the Mavic Pro Platinum is on the FAA compliance list https://uasdoc.faa.gov/listDocs but not the M2P? Just trying to decide if I need to buy a remote ID module in the next few months or sell my M2P. Thanks for any information anyone has.
2023-3-29
overdrive1337
The Mavic Pro Platinum has an DoC for RID. The recent and latest firmware update for the Mavic 2 Pro/Zoom, has an anti-rollback, which seems out-of-place. All other RID enabled/compliant firmwares on other drones also included an anti-rollback. Maybe that is an indication RID will eventually be coming to the Mavic 2 series. If not, I would sure like to know the reasoning for the anti-rollback, since the two previous firmwares were flawed and prevented certain parameter adjustments. So I would hate to be stuck with a firmware that potentially could also be similarly flawed. They sure don’t go into detail on firmware change logs..
2023-3-30
The Saint
Flight distance : 5902228 ft
overdrive1337 Posted at 3-30 14:06
prob all sw builds are flawed.  "anti-rollback" is not a good indicator of sw features or functions and is most likely based on some sort of policy.  i've also seen it implemented when going back to previous sw causes bad things to happen.  does dji force you to upgrade your sw?
2023-3-30
Trackerputnam
Flight distance : 5728392 ft
Ok, late to the game with rid. So on sept, 2023, I go to launch my mp2, will it not launch? (No rid)  I fly it happily without updating it. If it flies good, why update it. Thus on said day rid is required, what happens? I have a phantom 4 advanced, it’s so far behind on updates. Is it now worthless?
2023-4-11
DAFlys
A new cheap external RID module is coming from Dronetag,   special launch day price of $49 - https://shop.dronetag.cz/products/41-dronetag-bs.html
2023-5-11
IW9HIM
Flight distance : 3558671 ft
New firmware released 01.00.0797 for mavic 2 pro/zoom activate the remote ID function, the DJI GO4 app must also be updated to version 4.3.60, otherwise it won't take off...
Something is moving...
2023-11-25
