fans403fd0b5
rcrdps Posted at 9-14 19:31
Ok. I got past that error by doing the "cast your runes" where you just try different monitors on different PC's until you come up with something that just happens to match whatever in the world that DJI requires for this calibration seeing as there is no documentation or support personnel that seem to know what you should type in that box, or what exactly you should be looking for in a monitor that will work. In my case, I now have a 24inch screen on my Intel NUC computer. It is 1080p native. Has a DVI port, but I'm using HDMI-DVI adapter. HDMI from the computer.
So now on to the next hurdle. How to get past the greyed out Calibrate Button. Most on the internet say disable driver signing fixes this, but so far it hasn't for me. This problem along with the screen resolution problem has been going on since at least 2017,...... so I'm pretty irritated. Makes me want to get rid of this drone as soon as I get it calibrated. Judging by all of the history I've read on this issue, I'm quite certain DJI "engineers" do not read this forum, so I'm merely documenting my journey for the next poor soul searching for a solution.
FYI. I did decide to send my drone in. I found physical damage to a component on the pcb of the Downward Vision sensor, and thus far, i don't see where those are for sale.
This doesn't change my complaints about the software. It is impossible to troubleshoot when you have to jump through so many hoops just to get it to run. I'm still left wondering if the software isn't running right, or is it the damaged sensor? And someone mentioned it erases your calibration first, so I will be reluctant to "try" just for documentation sake when my drone is returned from DJI. |
