umair air2s
Hi, DJI community. I am a happy owner of DJI Ar 2s. The AC experienced a crash a few weeks back. The left leg was broken, which I successfully replaced. After I put the Aircraft back together, I started getting following errors:
Navigation System Error 30105.
Gimbal calibration error 40011. (Gimbal calibrates successfully in the app and responds to all movements, but the error doesn't seem to go away)
I reopened the AC removed the GPS chips and core board (I believe that's what it's called) gave them a good clean with contact cleaner and reassembled it back. To my surprise, it worked, and the AC was back operational. After an hour of testing basic functions, AC threw an error:
IMU not calibrated. Calibrate IMU 30055.
I started the calibration process, which gets stuck at 6% every time despite waiting for a long time. After reaching 6% progress, it says Calibration failed. Everything else works fine Gimbal moves ok and responds to all movements. The following errors are active right now:
IMU not calibrated error 30055
IMU calibration incomplete Error 30056
I later replaced the GPS module and GPS flex cable. Opened the IMU module and heated it with a hair dryer for 3 mins. Reassembled the AC but same errors. Any guidance please. Thanking in anticipation.
