crodriguez
Dominican Republic
DJI Natalia Posted at 9-16 02:23
Hi, there. Please check the following steps to see if your problem can be resolved:
1. Click the error report to enter the module self-check, and check which motor reports the error;
2. If the 0131 and above versions specifically show which motor reports an error, check them in order (3~9), if the motor is not displayed correctly (you can upgrade 0131 first) or multiple motors report errors at the same time (you can also find one of them first Check the motor in the order of 3~9, confirm whether it is the problem of the motor, and then check the plate problem), follow the order (check 7~9);
Hi,
After check Power ESCs, Motor, Etc. The problem was the Power Distribution Board, it was replaced and the problem was solved. |
