DJI R Multi-Camera Control Cable (USB-C)
3767 7 2022-9-22
OSMOPETE
Flight distance : 35118 ft
I have a new Ronin S3 Pro and want to run accessories like focus motor and camera control from my gimbal. I see there is an expensive DJI R Multi-Camera Control Cable (USB-C) and was wondering, is this a regular usb c to usb c cable I can buy on-line or does it have to be a special configuration cable?Many thanks
2022-9-22
Indio
Flight distance : 303373 ft
Austria
regular USB-C cable will not work!
2022-9-23
OSMOPETE
Indio Posted at 9-23 02:45
Yeah I tried all the cables I had on hand but none seemed to work
2022-9-23
DJI Natalia
Hi, there. Sorry for the late reply.
You may need to use our camera control cable.
You can check this link to check which camera control cable is suitable for you: https://www.dji.com/support/compatibility
Besides, if there is anything else that we can help with, please feel free to let us know.
Thank you.
2022-9-25
oberschneider.com
Flight distance : 4730358 ft
Austria
I'm using a standard USB-C to USB-C cable with my Sony Alpha 1 on the RS3 Pro, and it works like a charm.
2022-9-25
ValleyForge
Flight distance : 24754 ft
I read elsewhere that you can power a Tilta motor via the gimbal but only with a Tilta power cable.
BUT - I can tell you if it's a Sony FX6 there is no camera control from the gimbal. And I have tried EVERYTHING!
Hoping for a favourable firmware update; but then again aren't we all?
2022-10-2
willo330
I just purchased the DJI RS3 Pro stabilizer. I have it connected to a Canon C70. The camera control USB-C to USB-C cable that came with it seems not to be compatible with the latest C70 firmware v1.0.4.1. Nothing works!  I an seeing that the cable is called "Muti-camera control cable to USB-C", not USB-C to USB-C. DJI support could not say when an update to support the C70 is coming. Very Frustrating.
2022-10-3
infodougmac.com
Flight distance : 4407480 ft
I believe only the usb-c multi cable from DJI will work to power and control the DJI focus motor. I’ve tried regular usb-c cables and they wouldn’t power the motor.
2023-9-9
