fansb5035101
Flight distance : 277995 ft
DJI Natalia Posted at 9-24 02:00
Hi, there. If you want to import KML into PILOT, we recommend that you try a map platform that supports the creation of KML files. Such as the Ovital Map and so on.
Although we only tested for compatibility with KML of Google Maps, KML is a coding specification based on XML syntax and format for describing and saving geographic information (such as points, lines, images, polygons, and models, etc.) The created KML file, as long as the KML type that meets the requirements of the APP, such as line segment or polygon, can import geographic information into the APP to generate the range, but cannot save and perform some additional actions, such as the PTZ angle or actions under other tags.
Besides, if there is anything else that we can help with, please feel free to let us know.
Thank you for your reply Natalia. Specifically I am looking for documentation on those KML requirments and in particular all of the possible varibles that canbe utilized, such as those in the KML code sample below. As you mentioned there is a coding specification based on XML specifically for KML and I would like to get document on it so I can meet the requirements of the app as you suggested.
