djiuser_UAPzMrwJbYVy
Flight distance : 3127431 ft
It seems to happen when you you change airsense to the highest sensitivity (low, medium, high). If you do this and enlarge the map it will begin the crash process. A work around for this is to use the other two sensitivities and it will fix it from crashing repeatedly. At least this worked for me as I experienced it when I changed the sensitivty of air sense |
