Airsense on Air 2S vs. Mavic 3
705 6 2022-9-27
bhallapple
Flight distance : 9478576 ft
I use an RC Pro to fly either my Air 2S or Mavic 3.  I noticed that with the same Airsense setting, I can see Jets flying a few miles away when using the Mavic 3 but not the Air 2s.  Is the Mavic 3 just more sensitive, or are there some other factors?
2022-9-27
dreamtuner
Flight distance : 2232569 ft
Bangladesh
I haven't received one single ADS-B warning since Fly update v1.7.4.
Was wondering if DJI disabled it in the Air 2S somehow with the updates.
2022-9-28
bhallapple
dreamtuner Posted at 9-28 21:36
V1.7.4 would just crash with a message that says it stop whenever I would go to the map,  as long as airsense was set to the least risk setting.  Set it to medium risk and the app did not crash, but there were no warnings.   A lot of people reported including myself rolling back to 1.70 works.  still see a difference in sensitivity between DJI Air 2S and Mavic 3
2022-9-29
dreamtuner
Bangladesh
My Airsense setting has always been set on the Highest sensitivity. There are multiple air passages where I live and I have always received Airsense warnings every time I flew up until v1.7.4 installation. I usually don't roll back and now decided to wait for the next Fly app update.
2022-9-30
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We have noticed that the AirSense prompt in previous versions was too sensitive. For example, when a civil aircraft flies by at 1 km above the drone, a prompt will be given. As such, to ensure safety, we adjusted the AirSense function in v01.00.05.00. Please rest assured when you use your product. If you need to confirm whether the AirSense function is normal, please go to the app’s Map, and tap the aircraft icon to adjust the level of potential collision risks as required. Hope this helps. Thank you for your valued support.
2022-10-4
bhallapple
DJI Paladin Posted at 10-4 00:53
I see the planes flying without any notice miles away with my Mavic 3, but not with my Air 2s.  Kind of like seeing when planes are entering the area before warning, that prompted the question, is the Mavic 3 more sensitive than the Air 2S  for situational awareness
2022-10-4
DJI Paladin
bhallapple Posted at 10-4 02:56
Thank you for your feedback. We will coordinate this with our designated team for further clarification. We will surely keep you posted. Thank you.
2022-10-5
