DJI Paladin
Hi there. Thank you for reaching out. Hope that you could get the best recommendation from our fellow DJI members here that already have experience using this type of power bank. Please note that Osmo Action 2 can be used while charging. However, it does not support the quick charging feature because the power will be restricted. Charging power of up to 10W is supported. As such, we recommend that you use a standard USB cable with a 5V/2A charger. Thank you for your valued support. |
