Osmo Action 3 Screen Protectors
3515 9 2022-10-1
TJDeerinck
Hey Guys,
Has anyone sourced screen protectors for the Osmo Action 3 yet?  I know that the original has a different size lens.
Trying to find a place I can grab some.
Thanks in advance!
~TJ
2022-10-1
osmonauta
Hungary
---DELETED---
2022-10-1
TJDeerinck
osmonauta Posted at 10-1 15:21
Amazon?
https://www.amazon.com/Supfoto-Osmo-Action-Screen-Protector/dp/B0BFBR5KRL
Thanks for that Link.  I tried searching Amazon and nothing came up!  Probably had a moment of Cranial / Rectal Inversion going on.
~TJ
2022-10-1
osmonauta
Hungary
---DELETED---
2022-10-1
DowntownRDB
Flight distance : 1722 ft
Several on eBay also.  Here is the one I like.
https://www.ebay.com/itm/1239288 ... Ctkp%3ABFBMhKjsifNg
Many on AliExpress also.
https://www.aliexpress.com/whole ... 2g0o.home.1000002.0
2022-10-2
skysailor64
Does the application of any of these screen protectors alter the wet performance of the touch screens?  Do they alter/remove any of the lens protector coatings when removed?
2022-10-2
10-Bit
My suspicion is that a screen protector would alter the wet characteristics a bit.  Since the OA3 apparently has a new special coating for use in water environments.  We had a 3 piece set installed on the Action 2 - since the lens cover on that device was not replaceable.  Worked fine even when wet.  The only concern was potentially a bit more lens flare when shooting in certain angles to the sun.  Otherwise having another element in front was not noticeable and did not seem to affect IQ much at all.
Would think that your original coating would be fine if you took it off.  We never tried though.
2022-10-2
DJI Stephen
Hello there TJ. Good day and thank you for reaching out. You may try check our DJI Where To Buy platform on this link ( https://www.dji.com/where-to-buy ) to see if the screen protector for your new DJI Osmo Action 3 that you need is available. In addition I hope that you can get some recommendations from our DJI members with regards to this inquiry. Thank you.
2022-10-2
Nick87
Russia
Wouldn't lens protection degrade image quality?
2022-10-3
