Bigplumbs
Flight distance : 620164 ft
fansfe82067d Posted at 10-7 01:19
Of course not. Stabilisation isn't the same as gimbal functions. For instance, put an EIS camera on a pole, lower it to the ground in front of you, then raise it into the air (as in a reveal shot). On the Pocket cameras, you lock the tilt axis and when the camera is high in the air, it's still pointing horizontally at the subject. The EIS camera is pointing at the sky, which is not what you want. And then we come to low light. The Pocket cameras don't care if there's no light, the gimbal system works as if it was mid day in the tropics. The EIS camera will record a total mess of artifacts because it needs a fast shutter speed for EIS to work. Sure, you can set the shutter speed fast, but then the ISO maxes out and fills the image with noise. I could go on....
You sound horribly like a camera geek............ Believe me no good will come of it.
What about how impractical a pocket is to use and lay down and stop from getting wet and the camera seeming to do its own thing and not going where you point it..... I could go on |
