120ccpm
Flight distance : 1396755 ft
The message is completely incorrect and misleading, it happens when you try to enable QuickShots while in S or C mode. Switch to P mode and QuickShots will work, it has nothing to do with the GPS signal.
On a completely separate note, you're also getting a warning about the propellers rotating too fast. This has been covered at length here and there are very different opinions about it, with some believing it's a bug in the firmware. I think it's a legitimate warning and you should replace the offending props, no matter if they look perfect (when you land, the aircraft will signal which motor was spinning too fast).
