JJB*
Flight distance : 12225059 ft
DJI Stephen Posted at 10-11 00:48
Hello there FabioV. I am sorry for the trouble this has caused and thank you for giving out these information. Just a friendly reminder that when flying above water, the vision positioning function will turn off automatically and only the GPS and barometer are used for positioning, if affected by the accuracy range, and an accident might happen. In addition I will also post a DJI Forum thread on How to Fly Safely Over Water. Thank you and fly safe always.
https://forum.dji.com/forum.php?mod=viewthread&tid=181878
Hi Stephen,
And again you post this outdated link!! why ?
FlyApp drones cannot disable the VPS bottem sensor!!
And the vision positioning is not turned off automatically flying over water!
And what do you mean with "...affected by the accuranct range, an accident might happen" ?? It is so wrong!
I fly many times low over water, VPS bottom sensor does sense alway the correct height.Only when flying slow or hovering low over streaming water the VPS downward sensor gets sometimes "confused"....
Well, just my experience flying many many flights low over water.
And, analyzing logs, you can see that the vision is not used for positioning when the GPS signals are oke. (see the manuals as well ....)
Best for DJI is to change the autolanding protection such that it will automatically turns off with some speed in any direction! This has caused many wet drones....
Cheers
JJB |
