David_Harry
Yes, you would think it’s odd, especially given that it’s likely that Steady at 4K at certain FOVs is likely to be under the 4K’s optical resolution.
Given the obvious differences, it may also explain some of the issue that people are having with the 3 as far as certain softening of focus is conserved.
While I don’t doubt that some people have definitely got a misaligned lens on their Action 3. I’m going to bet that if anyone with a 3 does the same test as this that I’ve done with the 2. They are going to see similar results with the softening of the image in particular combinations of FOV and stability.
It’s clear that with the 2, the internal processing of the Action for selecting FOV, combined with particular geometry processing for stability, is definitely impacting on the quality/sharpness of what the sensor is capturing. |
