DJI Paladin
navig8uk Posted at 10-18 13:35
Thank You for your reply, I am using the DJI RC.
After syncing my records on the RC app, I can see the flight in question on the RC but I can still not find the txt file to download. it is obviously there somewhere but I can't find it on the RC. The RC says "1 flight records not uploaded" but when I try to upload it silently fails to do so. Can I download directly from the server or some other way?
Thank you for your response. For you to export the flight records on your DJI RC, you may follow the information below. Hope this helps. Thank you for your valued support.
1. Use a USB cable(A to C) to connect DJI RC to a computer. You will see “MTP USB Device” appear in “This PC.”
2. Double-click “MTP USB Device” to open the internal shared storage inside the remote controller. The DJIFlightRecord documents are the flight records. The corresponding flight records can be found, copied, and exported based on time. |
