Advanced Gimbal Settings for Cine Mode
2031 11 2022-10-23
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
Pitch Speed - corresponds to the settings from Normal mode (those. this setting in Normal mode affects both modes). This setting in Cine mode has no effect.
Yaw Rotation Speed - set up as expected in Сine mode
2022-10-23
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please confirm if you are having issues with this setting under Advanced Gimbal Settings? Can you please tell us more about the issue? You may configure each setting for Normal, Sports, and Cine Mode just simply scroll down for you to check the other options below. Please keep us posted. Thank you.
2022-10-23
Indio
Flight distance : 303373 ft
Austria
the error exists when the collision sensors are set to avoid.
a different setting works for the brake mode
2022-10-24
Drone.Hunter
Kazakhstan
DJI Paladin Posted at 10-23 20:02
Today I checked in nature. All settings in both menus for controlling the drone itself in Cine mode work correctly. The problem is only with camera control: Pitch Speed, Pitch Smoothness, which are taken from the Standard mode settings.
2022-10-24
DJI Paladin
Drone.Hunter Posted at 10-24 06:44
Thank you for keeping us posted. Kindly please provide us some screen recordings showing the issue for us to check it here on our end. You may upload it in Google Drive and send the link here. Thank you.
2022-10-25
Drone.Hunter
Kazakhstan
The problem appears when the mode is in Flight (motors on). When the motors are turned off, everything works correctly.
Google Disk
2022-10-25
Drone.Hunter
Kazakhstan
DJI Paladin Posted at 10-25 03:27
The problem persists with the new firmware.
2022-10-26
Drone.Hunter
Kazakhstan
Has the problem been verified???
2022-11-6
Drone.Hunter
Kazakhstan
Did testing.
1) If it is bright and the sensors work, then there is a problem with the speed of the camera tilt in Cine mode.
2) If there is not enough light, then the sensors will turn off, and the tilt control will become correct.
2022-11-7
Drone.Hunter
Kazakhstan
The above issue occurs when OA mode is enabled in Bypass mode. When switching to Break - no problem.
There are complaints from other users. This is their decision.
2022-11-10
Drone.Hunter
Kazakhstan
Here is a video from one of the users. I also have a similar entry.
From what I understand, this is an old problem. Are your programmers unable to diagnose the problem?
2022-11-10
Drone.Hunter
Kazakhstan
DJI, any information on this issue?
2023-1-5
