No Original Thought
Flight distance : 1364209 ft
Sean-bumble-bee Posted at 10-28 10:46
Isn't there a known problem or feature that causes the gimbal to move away from the extremities of is range when the drone is given pitch in the appropriate direction?
I have certainly seen the up-tilted angle I chose 'permanently' (until in a hover etc. I manually sent the tilt back up to 20?deg) reduced when I pitch the drone one way or the other, I think it was nose down.
I am not sure about when using full down-tilt and pitching the drone nose up.
From the reports I've read the issue isn't related to the gimbal limits.
Those limits kind of make sense as the gimbal may try to rotate out of range when the drone pitches up or down in order to try to maintain the angle relative to horizontal.
However, as this bug is described, the gimbal can still be titled up and down, but won't pass the 0 degrees mark. So it is as though the 'Allow Upward gimbal rotation' setting has been turned off - though the app still shows is as being on.
Turning it off and back on in the app then allows the gimbal to tilt up again - and my understanding is that you can even do this in flight which implies the gimbal isn't hitting limits and getting physically stuck.
Again, though, I haven't seen the problem myself (in fact I haven't managed to fly since reading about it! :-(. ) and so haven't been able to experiment at all, but I'll have a play next time I do get airborne. |
