fansf475763d
Flight distance : 611821 ft
DJI Paladin Posted at 10-30 02:47
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please confirm if you are referring to the settings that said: "Switch to DJI Digital FPV System" under the Reset All option on the DJI Goggles V2? Could you please try to toggle down on the very bottom under "About" settings to see if you found the said option? If you still experience the issue, could you please take a picture of the settings showing on your end for us to check? Please keep us posted. Thank you.
Thank you for responding yes yhsy is the option I am referring to. Unfortunately, it is not listed anymore. After the lipo died and it went into reset mode, and that option n is no longer in the about menu. This bug was a common issue back in 2021. As discussed by MaxTe h in this episode on his channel (https://youtu.be/g2TeIhofrq4). But like I alrasdy mentioned I did a firmware update and Powe cycled a few t Ines and it's dtikll missing form the settings, about menu. |
