Raveneye Stand alone RSS connection no working.
553 2 2022-10-30
Barramundi
Flight distance : 128 ft
I'm trying to connect the RavenEye to my Canon M6II which it shows is compatible, no gimbal involved. Stand alone mode.
The HDMI connection is working great, but I can not control the camera, Shutter button doesn't work when connecting to the Raven RSS port with USB-C Camera port.
Do I need a special cable ?
I don't have the Ronin SC2, just the SC, so I connected that righ angle RSS Ronin cable to the RavenEye and Camera
I also tried the USB-C cable right angle that came with the Raven, but did not work either.
I tried to connect a standard USB-C cable but none fit when the HDMI is connected.The RavenEye user guide doesn't explain which cable has to be used, and according to their diagram it should be a no included USB-C cable.
Any help is appreciated.
Thanks.
2022-10-30
ro_walker
Brazil
Very frustrating!
2022-10-30
Barramundi
Yes, it looks like I'd have to return it.
There is not even support for help.
I found a better solution using the Canon Camera App with a portable mini router, just $50 !
I can control a lot more settings and it can go up to 100' no propietary control cacles or HDMI connections to fiddle with.
2022-11-7
