DJI Avata "No M mode: UAV too high/far" error
4976 24 2022-11-1
Middle Tenn State UAS
Flight distance : 164816 ft
Hi I am having a problem with Avata M mode.
When trying to switch into manual mode, “UAV too high/far” error pops up, M mode is not being enabled.
It happens on any distance, including when I hover in a couple of meters far and high from takeoff point.
It used to successfully switch in manual mode in September, but then at some point it stopped switching into M mode.
I tried the following and it did't fix the M mode problem.
1. Remote controller sticks calibration
2. Linking different RC, with calibration
3. Enabling and disabling M mode attitude limit
4. Flying within and outside Flysafe warning zones, including totally free-of-any-restrictions zones.
5. Different aircraft firmwares, including oldest and the newest.
6. Different goggles (2 and V2)
7. Trying going into manual mode closer and further away from takeoff point
8. Playing with Altitude and Distance limits, changing them within all possible ranges.
Height and distance OSD readings are accurate and change accordingly to the flight path of the aircraft
I am flying DJI Avata for Middle Tennessee State University, which is an approved member of QEP program, so I even have Geozone unlocking for this aircraft.
I have tried M mode before and after unlocking.
Please help me making M mode back to work!
Thank you
Alexander Fomenko, UAS Lab Coordinator, MTSU
2022-11-1
DJI Gamora
Hi, Alexander. Thank you for reaching out and we do apologize for the trouble. We appreciate the detailed information. This concern is already been forwarded to our designated team and we are waiting for updates. As soon as we get one, we will surely keep you posted. Thank you for your patience and understanding
2022-11-1
DJI Gamora
Hi, Alexander. Thank you for patiently waiting. We have now received feedback from our designated team. Feedback is as follows: This warning indicates that the aircraft is limited in height and distance. It may have entered the restricted flight zone, or there is no binding account.
Since you mentioned that you unlock a Geozone, we presume that you were flying in a restricted area. May we please have the longitude and latitude coordinates of the area where you're trying to fly the drone? Also, we suggest flying in different flight environments to isolate the issue.
We will wait for your update. Thank you for your understanding and cooperation.
2022-11-2
DJI Gamora Posted at 11-2 08:08
Solved!
M mode is disabled when QEP unlocking is enabled, regardless of where I am flying.
September's successful flight in M mode was conducted before importing unlocking license into the aircraft. Apparently, ever after importing the QEP license, unlocking was ON at all times.
As soon as I turned off the unlocking, M mode became enabled.
Today I tried flying in both restricted and unrestricted zones and M mode kicks in just fine when unlocking is OFF.
Thank you
2022-11-2
DJI Gamora
Middle Tenn State UAS Posted at 11-2 11:53
Solved!
Hi, Alexander. Thank you for keeping us posted. We are happy to read that the issue has been fixed already. Please do not hesitate to reach us here in Forum in case you need further assistance. Thank you for your valued support!
2022-11-2
Lucho Gonzalez
Flight distance : 2383091 ft
Argentina
Middle Tenn State UAS Posted at 2022-11-2 11:53
Solved!
Hi, how are you?
Can you help me out? I have the exactly same problem !! BUT i do not understand something: if i turn Uncodking OFF will not allow me to fly on an NFZ. So how you handle that?
2023-3-3
djiuser_VyKdOq10fePE
Solved!
Hello and good day, can you elaborate on how to toggle this QEP, forgive my ignorance, but going through this issue as I live in a geo zone have applied for an unlock and it flies perfect ,but cannot get into m mode
2023-4-1
DJI Tony
djiuser_VyKdOq10fePE Posted at 4-1 15:25
Hi there. We're sorry for the inconvenience. We're sorry to inform you that Manual mode is not supported when you re in a geo zone. This applies whether you have unlocked the area or not. We recommend flying the drone in N or S mode when you are in a restricted zone or geo zone. We appreciate your understanding.
2023-4-1
BadBert
Flight distance : 59121 ft
DJI Tony Posted at 4-1 23:56
we have seen this reply a couple of times now.
but when you are clear to fly, you are clear to fly.... period.
it should not matter in what mode you're flying!
2023-4-2
DJI Tony
BadBert Posted at 4-2 23:51
We understand and we're sincerely sorry for the inconvenience. Please understand that our engineers need to consider all aspects before a certain suggestion or request can be implemented. Right now, there has been no feedback from them yet. So what we do is continue to gather such requests and let the related team know. We ask for your understanding and continued patience.
2023-4-5
BadBert
DJI Tony Posted at 4-5 00:27
i hope they fix it... ;)
thanks
2023-4-5
fans17c4995b
Flight distance : 18832116 ft
I agree, what does it matter what mode you’re in.
2023-4-5
KLRSKIR
Flight distance : 28368625 ft
fans17c4995b Posted at 4-5 19:22
Probably a far lesser chance of an accident in N or S mode. I'm just guessing here.
2023-4-6
BadBert
KLRSKIR Posted at 4-6 02:17
could be, but if you are allowed to fly (by law and regulations) you are free to fly in any mode.
So dji should not limit the user of their product
2023-4-6
KLRSKIR
BadBert Posted at 4-6 02:46
DJI is covering their butts! Their aircraft, their decision.
2023-4-6
The Saint
Flight distance : 5902228 ft
kinda works both ways, there could be instances where the gvt is more restrictive and dji makes the [correct] call.  i understand what it means in reality but imagine if your drone could only top off at 400agl from wherever you lift off from and not a foot higher because the "faa" says so.....
2023-4-6
BadBert
If you are flying within the rules, so height, distance etc, you should be able to fly how you want....
if you ARE to far/high, then yes i understand, but that is not the case here
2023-4-6
DJI Tony
BadBert Posted at 4-5 00:51
thanks
We appreciate your understanding. Stay safe!
2023-4-8
CagomoC FpV
Flight distance : 480026 ft
I have a similar issue, I am flying in a non restricted area private land and lI ike to take off in manual mode but soon as I get 10 feet away the drone goes into normal mode all setting is correctly set. Now what?
Here's how it goes Im taking off the is moved 6ft high then 10ft away then kick into normal mode. everytime since the latest firmware update today i repeated this steps 04/08/2023.
2023-4-8
Rueges
Flight distance : 124045 ft
DJI, THIS NEEDS TO GET FIXED ASAP. THIS IS UNACCEPTABLE.
2023-4-9
Rueges
KLRSKIR Posted at 4-6 14:31
This is an idiotic comment. There's nothing to "cover". Like others have stated, people that are experienced, certified, whatever the case may be, have legal authorization via the only flying authority that matters in the US (FAA). DJI needs to fix this, and leave matters as such in the hands of the FAA.
2023-4-9
KLRSKIR
"Idiotic" or not, it's true.
2023-4-10
djiuser_ueCkC3mENnbI
WOW U GUYS COULD HAVE SUCH A WONDERFUL MACHINE BUT YOU FUCK IT ALL UP  WITH UR BULL...! SO UR TELLING ME FOR A YEAR I HAVENT BEEN ABLE TO FLY THIS POS BECAUSE IM IN A GEO ZONE AND AFTER GOING THRU UR BULL... UNLOCKING PROCESS  We the public need to ask you to unlock manual mode in Geo zones!!! I FEEL LIKE U GAVE ME A PIECE OF GARBAGE. IAM SAVING UP FOR HDZERO AND WALKSNAIL IS FINALLY COMPARABLE  GOOD BYE DJI
2023-6-25
I FOUND THE SOLUTION GET A DEFENDER 25!!!
2023-6-25
fans5708782c
Flight distance : 11308691 ft
What’s the distance limit for flying in manual mode for the avata, if not in a geozone or boundary?
2023-12-13
