Can't import aircraft - Disconnected aircraft
491 3 2022-11-9
leonvski
Brazil
I can't fly with the drone. In "account unlocking licenses" everything is ok, but in "aircraft unlocking licenses" nothing appears. And when I try to update the message appears "failed to update the list of aircraft unlock licenses". And it doesn't give me the option to import aircraft. Also, an expired unlocking license appears that doesn't disappear from there... I've done all the procedures on the official and unofficial website... Could you help? Everything is up to date. I accessed the forum and they said that this has already happened to a guy and that he had to get in touch to "clear the settings" or make the release by dgi himself.. and it solved... Thank you!
screenshots.pdf
625.13 KB, Down times: 0
2022-11-9
Montfrooij
Flight distance : 2560453 ft
Hi,
You might be better off posting in the products section of this forum. That is way more active!
https://forum.dji.com/forum-129-1.html
2022-11-10
leonvski
Brazil
Montfrooij Posted at 11-10 00:58
Hi,
Thanks! i'll do this
2022-11-10
Montfrooij
leonvski Posted at 11-10 03:21
You're welcome!
2022-11-10
