Bashy
Flight distance : 2354357 ft
fansebfd0e0b Posted at 11-13 21:10
it was 3m away from me and it was at 50 meters of height. the signal was full bar and the video footage was normal, then the visual transmission suddenly just went black. i had flown it much farther and higher than this before and it had no problems. this time it was weird.
Thanks, as stated already, if you're under the drone it can lose connection unless the RC is pointed upwards at the drone, to be fair, that would be an uncomfortable viewing angle so this is highly likely what happened.
The Mini 3 Pro is less forgiving in this regard too as it really prefers a good direct LOS to the RC, i.e. it needs to be pretty much spot on when at a distance thats not local, the antennas are very much directional. What i mean there is to save confusion, i mean the top of the RC where the antennas are needs to be aligned to the drone so you can imagine what its like when the drone is directly above you (3m is pretty much the same), for a comfortable viewing angle, you would be pointing the RC at what, about 45 degrees? thats pointing away from the drone. Other DJI drones are more forgiving in this respect and this is why many think that there is a range issue, especially when coming from a previous model, ok, I'm rambling now. It should be easy to replicate if this is the issue, go back to that spot, fly at the same distance and the same height, and in turn point to 4 points on the compass leaving about 5 seconds between each turn but holding the RC in your relaxed comfortable viewing position, i.e. not pointing at the drone at all. Hope this helps |
