DJI Tony
RobConley Posted at 11-10 05:21
I have the same problem with a new Mavic Zoom 2. Has anyone come up with a solution to land to drone manually. This scenario seems to happen randomly to me and has nothing to do with the landing surface, I use the concrete driveway.. Last time I couldn’t even grab it from the bottom, it will shoot up when I reached for it even with the stick down. Had to run my battery all the way down before it would land. Now the battery might be screwed, won’t charge, hopefully the battery is only in hibernation mode. DJI, can you give us the solution?
Hello there. Are you still experiencing the issue? Please try the notes below:
1. Please check whether the remote controller’s control stick mode and the control stick operation are correct. If the control stick mode is Mode 2, push the left control stick downward to land.
2. Calibrate the remote controller and ensure that the remote controller’s control stick can respond normally.
3. Check whether the landing ground meets the conditions (for example, whether the ground is flat, or whether there is a water surface). When the Downward Vision System works and the ground does not meet the landing conditions, the aircraft will hover and wait for the user’s further operation.
4. Check the flight environment and avoid flying through clouds or in a heavy fog environment, which will affect the Downward Vision System.
5. Check whether there are payloads under the aircraft that may affect the Downward Vision System.
6. Try disabling the Downward Vision System and test it. If the aircraft can land, it can be determined that the Downward Vision System is malfunctioning. Please perform sensor calibration using the DJI Assistant 2. You can use this link to download it to your computer: https://www.dji.com/downloads/softwares/assistant-dji-2-for-mavic
Please keep us posted. Have a great day ahead. |
