unound.one
Croatia
An hour ago I had my first real flight using Phantom 4 and something happened which I can't understand.
After that I learned about flight data log, and even lookin at log I don't see anything abnormal but still can't comprehend this behaviour.
So here it is :
I'm flying the drone in P-GPS mode, home distance 539.0ft, alt is 114.2ft and I hit RTH.
RTH height is set to 60m in app.
log reads : RTH: Heading alignment.; Aircraft is returning to the Home Point. RTH Altitude is 60m. You can reset the RTH Altitude in Remote Controller Settings after cancelling RTH if necessary.
2 seconds afer it reads : RTH: Ascending to RTH altitude.
everything fine until this point because it was lower than set attitude.
It doesn't stop rising after 60m (196ft)
At one point it reaches 397.0ft so i get : Altitude above the takeoff point exceeds 120 . Always fly in compliance with altitude limitations.
It's still rising , at 442.9ft i get : Maximum Flight Altitude Reached.
So i start to panic and hit sticks and in log I see it switches to P-GPS so I manually descend and land it safely.
Does anyone have any explanation why this happened? Log is not usefull in this instance.
