LivingstonS
Flight distance : 334656 ft
Sweden
Thanks. It seems there is no way to remove location data from the log viewer, and (of course?) I don't want to post my location data publicly online...
I took some screenshots from the most interesting parts of the log, please see the attached pictures.
What I can see in the log is that the VPS Altitude went down to 2.0ft while the IMU Altitude was still at 58ft. That's when the Fllight mode went into Confirm Landing.The VPS Altitude then continued to decrease to 0.3, and then N/A.
A few rows later I can see that I pressed Up on the controller, and the Flight Mode went back to P-GPS again.
Then I continued descending again, and the VPS stayed on N/A until IMU was at 36.7ft, at which point VPS went to 22.6ft and then continued decreasing. This time it behaved like a normal landing.
Also, after takeoff the VPS and IMU altitude were almost identical up to 36.7ft VPS / 39ft IMU, after which VPS went to N/A.
Could it be some kind of calibration issue? There were no warnings or anything about calibration. The VPS sensors look clean, and there's nothing that could be interfering with them.
The second flight followed the exact same pattern.
I should perhaps also add that I was landing between two 7m (22ft) tall buildings, approx. 20m (65ft) apart. I have done that before without any issues though. The only thing different from all my other flights is that the ground is covered in snow and the temperature is slightly below freezing.
Start of false landing
End of false landing
Start of VPS before real landing
Real landing
