3th party wide angle lens distortion
782 4 2022-11-21
blocker87
Hello,
I got a 3th party wide angle lens but its very bad.
It has extreme distortion around the edges.
Question: does the original DJI lens less distortion.? Is it good?
2022-11-21
hallmark007
Flight distance : 9827923 ft
it does but its slight and very easy fixed. What lens are you using?
2022-11-21
blocker87
Ulanzi wide angle...
Was looking for original but is nowhere in stock
2022-11-21
DJI Tony
Hi there. Thank you for reaching out. We are sorry to read about the poor experience with the third-party wide-angle lens. DJI Mavic 3 Classic has its official DJI Mavic 3 Classic Wide-Angle Lens, and we highly recommend that you use it as performance is guaranteed. If out of stock, you may select the "In Stock Reminder" so you will be notified once it's been restocked. You may also check with our affiliated retail and online stores for availability. Here is the link: (https://www.dji.com/nl/where-to-buy/retail-stores). Should you have any concerns or inquiries, please do not hesitate to reach us here at DJI Forum. Thank you for your continued support.
2022-11-21
MaxP4
Flight distance : 13833304 ft
Buying a drone with a great camera and then using crappy lenses is crazy.
Unfortunately, good lenses like DJI or PolarPro (the only ones I would recommend besides DJI) are expensive but worth it.
2022-11-26
