FOV in Goggles V2 not changing
713 10 2022-11-25
Pajomota
Flight distance : 710197 ft
Portugal
Hi. I have the Avata with Goggles V2. I can not see on the screen the changes in FOV when switching from Norma/Wide/ Ultra wide. Is this normal?. The final video files show the different FOV but not when I'm flying.
2022-11-25
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we do apologize for the inconvenience. I just want to clarify this query of yours for us to provide you with an accurate resolution. When you switch between Normal/Wide/Ultra, it doesn't show any changes on your Goggles/Livefeed, correct? However, the recorded video that was saved on the SD card doesn't have any issues. Please confirm. Thank you.
2022-11-25
Elephant Apocalypse
Flight distance : 5538606 ft
DJI Paladin Posted at 11-25 19:44
Same here, when changing wide, normal, fov in goggles doesn’t change output recorded does
2022-11-26
DJI Paladin
Elephant Apocalypse Posted at 11-26 09:57
Thank you for the confirmation. I will coordinate this with our designated team for further clarification. We will keep you posted. Thank you.
2022-11-28
Pajomota
Portugal
Hi. Yes that's exactly the case. Only the final sd card or internal memory videos show the different FOV's. The live feed on my V2 Goggles doesn't change.
2022-11-29
Denmar
Poland
Hi, I have the same problem with that. Did you get any solution from DJI?
2022-12-17
ro_walker
Brazil
Same here.....
2022-12-17
Pajomota
Portugal
Denmar Posted at 12-17 04:57
Hi. Not yet.
2022-12-17
Denmar
Poland
Hi... I received the answer from DJI concerning that problem, but it looks like a joke.
"Greetings from DJI.
We've re-confirmed with our senior engineer. The camera FOV will not change the view in the camera view of the goggles, while the shooting footage will have the "wide/ultra wide" effect. Thanks for your understanding and support.
Thanks for choosing DJI!
Best Regards,
William
DJI Technical Support"
It looks like they're joking.... So, DJI suggests that I can't see in my goggles what the camera exactly sees? Do they know what does the FPV mean? First person view! VIEW! VIEW! Goggles are the only way to observe the path of the quad! I'm completely disappointed! That's not what I expected from the DJI company. I hope they 'll take that under consideration making the firmware update. And I hope they will  fix it ASAP. Otherwise that would be the last DJI quad I bought.
2022-12-30
PiEz
Flight distance : 94498 ft
The FOV in the DJI googles 2 is far too big for fpv.I thought the issue would be resolved finding the ultawide/wide etc setting in the googles but it does nothing to the in google view and only effects the sd card footage.This is madness!!! Wheres the setting to alter in google fov DJI support ???? these googles are pretty much useless for flying tight gaps as they are.What on earth is going on here.Are we going to see a firmware update to fix this ?? like asap ?? ive just paid over 700 uk for these googles and they are no use at all really
1-13 08:10
Pajomota
Portugal
Denmar Posted at 2022-12-30 12:21
Hi. Unfortunately I was hoping for something like that from Dji. Sometimes it seems thT they don't give a f#@#@#ck!!!
1-15 13:57
