Mini 3 RC Drone WiFi not showing on my phone
664 3 2022-11-26
Ralph111
Hi, Just got a Mini 3 pro RC two days ago.
I cant get a connection to the DJI Fly Quick Transfer option. My phone (Blackview BV 9800 Pro on Android 9) does not see the WiFi from the Drone. If I go into the WiFi settings on the RC controler, I see the WiFi the Drone generates, but not on my mobile and not on my computers. Bluetooth and WiFi is activated, I tried setting to 2.4 Ghz, the phone "sees" the drone with Bluetooth and gives the option for Quick Transfer but after that the connection is not possible.
Tried Firmware update with DJI Assistant, nothing helps.
Why does the RC controller see the WiFi of the Drone and my phone does not?
Greetings
Ralph
2022-11-26
DAFlys
Hi! You might be better off posting your question in the 'products' section of this forum.  That is way more active.    -   https://forum.dji.com/forum-129-1.html
2022-11-27
Ralph111
will try... thx
2022-11-27
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please try to use a different mobile device to see if the issue persists? It seems that the mobile device that you are using a not listed on our recommended mobile devices and this might be the main cause of the issue. We strongly recommend using a compatible device to avoid issues. You may refer to the link below. Thank you.
https://www.dji.com/downloads/djiapp/dji-fly
2022-11-27
