DJI O3 AIR Unit LONGER coax camera cable
4039 10 2022-11-30
fans0ba50d62
Flight distance : 85971 ft
Austria
Hi,
are there longer coax cable available?
I'm not able to place O3 Air Unit in the back of my 5" quad and the camera in front, so I get props out of view.
I'd like to have antenna in the back of the quad, as usual. I think this is the best place for it. I also thought about antenna with longer cables, but not sure, if this will downgrade transmission/signal quality, when routing antenna cables through the whole quad, below FC/ESC. Another option would be to place antenna somewhere in front pointing upwards or downwards, but then - depending on flight direction - the quad/frame could interfere the transmission/signal.
anyone any ideas or alternatives?
2022-11-30
Depp
Flight distance : 1868796 ft
It should be possible: Just saw a rather long (but custom) one here: at around 7:00
2022-11-30
fans0ba50d62
Austria
Depp Posted at 11-30 04:46
It should be possible: Just saw a rather long (but custom) one here: https://www.youtube.com/watch?v=txU3DEozchY at around 7:00
thanks for sharing
exactly the cable I'm looking for
sadly i-flight doesn't list it on their website.
anyways, interesting routing of antenna cables in this video. crossfire passes ESC + FC and they use an UF-L to RP-SMA adapter cable. normally I would avoid both. maybe I should look for an antenna adapter cable as well, till a longer coax camera cable is available.
once more, thanks for sharing
2022-11-30
fans0ba50d62
Austria
fans0ba50d62 Posted at 11-30 06:17
thanks for sharing
there is one available in iflight shop, but no details about length and if it's for O3 Air Unit
https://shop.iflight-rc.com/fpv-air-unit-coaxial-cable-for-chimera7-hd-pro1472
2022-12-1
DubSound
Flight distance : 104459 ft
fans0ba50d62 Posted at 12-1 06:06
This is for the Air Unit/Caddx Vista and is 200mm in length. Further down the page shows you the specs of the cable.
2022-12-1
fans0ba50d62
Austria
DubSound Posted at 12-1 14:59
oh yes - haven't scrolled down enough - thanks
2022-12-2
airtakes
Flight distance : 623045 ft
Question this 200mm length coax cable does it work with the new DJI O3 camera and air unit ?
or it is only for the Caddx Vista ?
thanks
2022-12-2
fans0ba50d62
Austria
airtakes Posted at 12-2 09:13
thanks
Mads Tech mentions, that pin count is different
cheers
2022-12-2
fans591f5a45
I am looking for shorter one
2022-12-3
DubSound
Seems like RunCam are selling some O3 compatible cables. Will probably end up purchasing one and seeing how good they are. They look to be the same sort of braided cable too.
https://shop.runcam.com/compatible-dji-o3-coaxial-cable/
2022-12-8
fans0ba50d62
Austria
thanks for sharing.
will order one as well
2022-12-8
