HGDC84
Finland
Does the receiver have a hotshoe/coldshoe mount? If it does, there are some adapters for the Pocket 2 that enable you to connect hotshoe/coldshoe mounted devices to it. For example, I have the PGYtech Dataport to coldshoe adapter for the Osmo Pocket/Pocket 2, and the Osmo Pocket Extension Rod has a coldshoe adapter mount built-in.
I also have a DJI Mic and can plug that to the DJI Pocket 2 using a 3,5mm wire and mount it to Pocket 2 using those adapters, or by using a coldshoe slot on my LED panel. Do know though that with the PGYTech adapter, you might need something between the mic receiver and the adapter to tighten the connection (unless your receiver has a fastening mechanism such as a mount wheel). For me, it is way too loose with the DJI Mic receiver unless I put a piece of rubber strip between them. |
