djiuser_SrrIUWy2ZhDK
Flight distance : 4442 ft
Turkey
DJI Tony Posted at 12-2 21:23
Hi there. Thanks for reaching out! May we confirm if you are using P Mode or S Mode? You may switch the flight modes from the remote controller itself. P Mode works best when the GPS signal is strong (P-GPS). This flight mode will enable the Intelligent Flight Modes including QuickShot, TapFly, Gesture, Tripod, and ActiveTrack mode. As Captain Wolferi mentioned in the comment above, you may consider Tripod mode. In this mode, the maximum flight speed is limited to 2.2 mph (3.6 kph). Responsiveness to stick movements is also reduced for smoother more controlled movements.
Note: Only use Tripod Mode when the GPS signal is strong or in light conditions suited for the Vision System. If the GPS signal is lost and the Vision System does not function, it will automatically switch to ATTI mode. In this case, flight speed will increase, and the aircraft will not hover in place. Use Tripod Mode carefully.
You may refer to the User Manual (page 18) to review the functions of the flight modes.
thanks a lot, take care
