Quick transfer for Air2s
2954 3 2022-12-1
htx
Flight distance : 531555 ft
Is Dji planning on updating the software on the Mavic Air 2s to allow "quick transfer" like the mini 2 and 3pro? This doesn't make sense that the mini 2 has the quick transfer feature but the Air 2s doesn't.
2022-12-1
DJI Tony
Hi, htx. Thanks for reaching out, and apologies for any inconvenience caused. DJI Air 2S does not support the QuickTransfer function as it was designed with a compact body while meeting heat dissipation requirements. Consequently, it cannot accommodate the hardware required to carry the QuickTransfer feature. Your understanding is highly appreciated, and thank you for your continued support.
2022-12-1
djiuser_zcBqJZMLA9dT
Poland
DJI Tony Posted at 2022-12-1 20:39
Is it possible to use DJI air2s with DJI-rc and use fast transfer features?
5-16 23:45
DJI Wanda
djiuser_zcBqJZMLA9dT Posted at 5-16 23:45
Hello, there. DJI Air 2S does not support the QuickTransfer function as it was designed with a compact body while meeting heat dissipation requirements. As such, it cannot accommodate hardware required to support the QuickTransfer function. We apologize for the inconvenience. Thank you for your understanding.
If you would like to transfer footage by using DJI Air2s and DJI RC, we will recommend you use FlyShare.
Here are the information:
How do I transfer and download footage via FlyShare when using DJI Air 2S with DJI RC?
Method 1: Download the footage from DJI Air 2S to DJI RC, and then transfer it to DJI Fly using the FlyShare function.
Method 2: Remove the microSD card from the drone, insert it into DJI RC, and transfer the materials in the card to DJI Fly using the FlyShare function.
Note: If a microSD card is already inserted into the DJI RC, pull it out first and store it properly. After inserting the microSD card into DJI RC, tap Album > Saved, and select the desired folder.
It is recommended to use method 2, which is more efficient and convenient. Note: The materials in Aircraft Album are displayed by default on DJI RC. Tap “Saved” if you would like to preview a material in the microSD card.
5-17 04:17
