Bashy
Flight distance : 2354357 ft
A bit of a light read, sorry, got carried away lol
1stly, matey in the video is stuck behind trees for the distance he is at, also he turns to the left and looking at the radar his RC compass is not calibrated, this, in turn, tells us that he's not even facing the drone until its gets closer to him on the RTH journey, how do we know that? well, even when the RC compass is off leading to the RC indicator being misaligned, it still turns GREEN when there is a good alignment, if its blue its a poop alignment. So thats 2 issues that didn't help his cause plus he's in a WiFi congested area.
I am in CE and the Mini 3 Pro performs a little better than the Mini 2, my village is very similar to his home location and i can get 1.2km, its the houses and trees that hamper my signal, the same as in that video. In FCC i can do around 1.5km with the exact same flight path.
In CE rural it has managed a decent 5.5km at only 31m high. That could well have been a one off, i am still to replicate that, the last time i tried using the exact same rural flight path, it could only do 3.3km. In FCC it managed only 6km. So, external factors being manmade or atmospheric play a big part in things.
Back to the problem with the RC to AC alignment, this has to be 100% spot on, there is no wiggle room. Not only that, the issue is exasperated 100% when there are objects in the way as already mentioned.
Get the RC's or other device's that you're using compass calibrated making sure the RC to AC indicators are spot on, then try your flight again and keep the top of the RC (where the antennas are located) pointing at the drone, bearing in mind that at a distance of 1500m and 120m high, the drone is only around 4 degrees off the horizon, that means that your RC should be pretty much flat and uncomfortable to view the live screen, you have to live with that if you want decent range. The further away the drone is from you, you should be lowering the angle of the RC, imaging that there is a laser dot coming out of the top of the RC, keep that dot on the AC at all times and you will get the max distance possible on that day.
Never think that you will be able to get the max specification every single time you go out, never gonna happen. Youre in CE so unless you're in FCC mode, you're hit with much lower-powered wifi from the get-go, the lab specs says 8km (CE), these will be the specs from the manufacturer of the components, of course DJI will market the max for all to see as thats what will help with sales ;)
If you're not getting anywhere near spec then you have to look at the reason why, its rarely down to software (Candian issue aside) or hardware, its pretty much either the pilot at fault (alignment) or other external factors such as interference from other radio signals or atmospherics.
As an afterthought, i wonder if "skywave" or "skip" plays any part in our signals, maybe the signal is not far away enough to have any effect? but when there is a "good skip" thats the radio waves reflecting back from the ionosphere, radio signals improve quite a bit for Ham radio, their contact distance is aided quite a bit by this. Probably a daft thought as our signal cannot even reach the ionosphere... lol |
