LV_Forestry
Flight distance : 4726654 ft
Latvia
If you are in the learning phase, there are a few exercises you can do.
1st exercise, (PITCH & ROLL) In a open space, you take off the drone with the camera oriented in the same direction as your are watching. The commands will be in the correct direction. You practice describing a rectangular pattern, without changing the direction of the drone.
2nd exercise, (YAW) Still in open space, you will now redo the same rectangular pattern but this time always orienting the camera of the drone in the direction of flight. For that you will have to use the yaw axis. At each angle you stop the drone, you make it turn with yaw, then you start again.
3rd exercise, You will combine Yaw pitch and Roll in order to perform the rectangular pattern without stopping the drone.
4th exercise, You redo the two previous ones but this time by describing a figure eight instead of the rectangle. The two loops must be of identical dimensions.
5th exercise, (FPV) You will place an object in the middle of the open space. The goal is to center the object with the camera and to go around it while maintaining the distance. Get into the habit of not staying focused on your screen, perform a drone/screen circuit in order to always have an eye on the drone and its environment. Already because it is provided for by law, and above all it will save you from going to look for it in a tree.
When you master this you will no longer ask yourself the question of how to go to 45 degrees. It will become a reflex.
The overall objective is to feel comfortable in your piloting and to control your trajectories.
