DJI Wanda
Hello, we let our engineers check your videos and problem:
We will put the solutions of your issues here separately:
The interference issue:
1. The DJI Mic transmitter adopts an advanced antenna design to achieve a communication range of 250 meters while having stronger anti-interference capacity. This may happen when the transmitter is used with a collar microphone with poor anti-interference capacity.
If this happens, we recommend that you keep the collar microphone away from the transmitter (the top left side of the DJI Mic transmitter) antenna or use a collar microphone with better anti-interference capacity to obtain better audio pickup effect.
2. The human body contains a lot of water and absorbs most RF energy. When there is one person between the DJI Mic transmitter and receiver, the wireless signal will be greatly attenuated, which will affect the audio transmission. During shooting, do not use the DJI Mic against the receiver to achieve the maximum range of signal transmission and ensure usage effect.
The jump cuts issue:
1. Check whether the DJI Mic’s firmware is the latest version.
2. Check whether the transmitter has been connected to an external microphone.
* If so, disconnect the external microphone for independent testing and determine the component which is malfunctioning .
3. After formatting the transmitter’s internal storage using the receiver, conduct an independent recording test.
* Before formatting, please back up the audio file in the transmitter’s internal storage.
4. Test another transmitter and see if the same issue occurs. |
