RC1B remote bricked
761 7 2022-12-30
wanderivth
Flight distance : 18776 ft
I put it away with about 75% charge on it.  When I got it back out it does absolutely nothing.  Doesn't charge, doesn't display the level of charge, nothing at all.  It's currently sitting hooked up to the OEM charger where it's doing nothing.  I've tried holding the power button for 20 sec.  That did nothing.  Any thoughts?
2022-12-30
DJI Wanda
Hello, there. Sorry for the inconvenience. Would you please try to charge the remote controller with different chargers and cables? If the issue persists after trying that, please send it back for repair. Here is the link: https://repair.dji.com/repair/index
2022-12-31
djiuser_cTjp0ORI45oC
Lebanon
Hi guys I'm having the same problem
I'm trying to turn the rc controller related to the dji mini 3 Pro but it not responding and not charging,any help
2023-1-3
DJI Wanda
djiuser_cTjp0ORI45oC Posted at 1-3 06:51
Hello, there. Sorry for your inconvenience. May we know did you try with different chargers and cables?
2023-1-3
Lebanon
DJI Wanda Posted at 1-3 22:51
Yes I have tried many different chargers and cables
2023-1-4
DJI Wanda
djiuser_cTjp0ORI45oC Posted at 1-4 00:12
Thanks for your reply. You may try to charge the controller longer and see whether it would respond. If the issue persists, please apply for an online repair request and then send it back for testing. Here is the link:
https://www.dji.com/support/repair?site=brandsite&from=footer
2023-1-4
Lebanon
DJI Wanda Posted at 1-4 01:36
I put it in charge for long time  with different charge
I will go to the link
Thank you
2023-1-4
DJI Natalia
djiuser_cTjp0ORI45oC Posted at 1-4 04:24
Thank you
You are welcome, if you need any support or have any questions, you can contact us here anytime.
Thank you for your support as well.
2023-1-5
