Quaxo76
Flight distance : 479386 ft
Malta
Hello,
So I logged more than 300Km on my Mini 2. It still flies perfectly, and it never had a crash at all. But now I'm a bit concerned about the propellers. I visually check them, and their screws, before and after each flight, and I see no change; but how can I know if the screws are still fully locked? They still look OK, but what if one or more are starting to unscrew themselves? Normally I would just slightly tighten them with a screwdriwer, and so I would notice if they were getting loose. But these have thread locker: if I tighten a screw that's still good, I will break the thread locker.
So what should I do? Is the basic visual inspecion enough, or should I just replace the propellers (and screws) after so many flights, even though they're still good?
And what thread locker should I use? I've read that many types do not harden when used on aluminum...
Thank you
Cristian
