DJI Wanda
Hello, there. Sorry for the inconvenience. Would you please check the following steps?
1. Please change the flight direction and try again to avoid the influence of wind from certain angles.
2. If the aircraft flies slowly in each direction, we recommend landing the aircraft as soon as possible and going to another environment. We also recommend users have a try in an open environment with less wind and at a lower attitude. (We do not recommend that fly their aircraft too high because the higher the altitude, the greater the difference in wind power. As such, the purpose of their testing cannot be reached.)
3. Please check whether the propellers on the drone are damaged or bent. If they are found to be damaged/bent, use new propellers if possible, and try again.
4. Please check and switch the flight mode, and see if the flight speed is slow in different modes. (It is best to check the speed that can be reached in different modes.) |
