The Saint
Flight distance : 5902228 ft
blue_canyon21 Posted at 2-26 15:12
I think that the FAA should at least provide some kind of voucher or discount for the RID module. Kinda like when the FCC changed broadcast TV from analog to digital, they mailed out coupons for people to buy converters for their TVs.
Or they should at least make the law only applicable to drones made/purchased after a certain date.
i agree and i believe the faa is trying to use "time to adjust" as their rationale except they are not allowing enough time. a few years is not enough. it should be closer to 5 to 8 years before drones are "prohibited." that way, you can't complain if your 6 year old drone don't meeting the new rules since you've had many years of opportunity to comply. obviously the manufacturers haven't helped but it's probably because they want you to abandon the non-compliant drone and buy one of their new ones.
i wouldn't want this process to be super complicated but if you have a non-compliant drone and you bought it in the past 5 years and the manufacturer will not update rid, the manufacturer should be able to either supply a low cost module or a govt subsidized module so you can be compliant even if that module only works for you and/or your drone (not other pilots, not other manufacturers). my evo2 v1 is going to fall thru the cracks and i honestly feel like it's one of my best drones and it has a good couple years left in it; i'd hate for it to get grounded.
btw, i don't mind paying $100 for a module that will work with any drone, forever. i'd rather not have a govt issued module but i wouldn't mind a govt check to pay for it. ;) |
