Montfrooij
Flight distance : 2560453 ft
Neico Posted at 1-10 10:40
I use mains through charging ports to give continuance on all active cameras based in the studio. never a problem. Sony AX 700, DJI Pocket 1, DJI Action 2. But certainly would take on board anything DJI recommended.
My rule of thumb, born out of the few Manuals I've looked into, is that if it is a charging power supply then it can be a driving power supply with the frequent note that if the power is being used in driving then it is not charging. However that could be old data, the new data is simply live tests - everything still works well on my assumptions.
With P2 I had bad results when using a powerbank (unfortunately).
Could be my powerbank, but DJI states it will damage the battery.
Maybe because it tries to charge AND use power for operating at the same time (and they have not programmed the P2 to work in 'OR', like use power for charging, or use it for operating).
But that is a wild guess.
My other cameras have no issues with this for sure.
I never tried a main outlet, since I only make timelapses out in the open.
(so I would like a solution for that, not for when I'm close to an outlet)
