Sony 6xxx series with Sony 18-105
947 3 2023-1-12
Obrva
Croatia
Hi,
can anyone tell me (or did it tryed) does the DJI RS 3 Mini work (can stabilize) Sony 6400 (6xxx) Series with Sony 18-105 f4 lense? Tnx
2023-1-12
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Yes, the Sony A6400 is compatible with the DJI RS 3 Mini. You may check using the link below for the list of recommended lenses for the said product. Please don't hesitate to reach us if you have other inquiries. Thank you.
https://www.dji.com/support/compatibility/rs-3-mini/a6400
2023-1-12
edz24
Latvia
DJI Paladin Posted at 2023-1-12 20:12
And does it stabilise perfectly in vertical mode?
3-5 14:49
DJI Paladin
edz24 Posted at 3-5 14:49
Hi there. Thank you for reaching out. DJI RS 3 Mini can switch to vertical shooting without additional accessories such as the vertical camera mount. You only need to attach the standard quick-release plate to the vertical arm. The steps are as follows.
1. Loosen the red lever on the lower quick-release plate, and then move the lower quick-release plate while pressing the safety lock beside the lever.
2. Loosen the lever on the horizontal arm, slide the horizontal arm down and unlock the safety lock on the bottom of the vertical arm to separate the horizontal arm from the vertical arm.
3. Make sure that the red lever of the lower quick-release plate is unlocked and points upward when mounting. Make sure that the red arrows on the side of the lower quick-release plate and the vertical arm are in the same direction. Align the lower quick-release plate with the groove of the vertical arm, install the lower quick-release plate, and then tighten the red lever.
Note: DO NOT install the lower quick-release plate in the wrong direction. Otherwise, the camera will not be properly secured to the vertical arm.
4. Make sure the lever on the lower quick-release plate is the unlocked position. Insert the camera and upper quick-release plate into the lower quick-release plate.
3-7 03:02
