DJI Avata - Camera Angle Fluctuates in Acro Mode
1118 4 2023-1-15
fans59505ce8
Flight distance : 364911 ft
Hi,
Recently bought the AVATA and took for a flight today in manual mode with no wind.
I set the camera angle to 3 degrees and encounted two problems...
1. The camera angle sporadically 'moved' whilst flying between 15 degrees and -3 degrees.
2. When I tried to adjust the camera angle the scale on the right side of the DJI Goggles 2 would show intermittently then dissappear when my finger was on the scroll wheel.
Why is this please and how do I stop it from happening?
Also, there has been an exposed wire on the drone since I opened it... Is this common with the Avata/could it be leading to a roaming camera angle?
2023-1-15
fans59505ce8
DJI any comments?
2023-1-18
DJI Wanda
Hello, there. Sorry for the inconvenience. May we confirm that: 1. Does it works normally in other modes? 2. Can we have a larger picture of the exposed wire to confirm where it is?
2023-1-19
fans59505ce8
DJI Wanda Posted at 1-19 00:02
The exposed wire is the wire to the camera from the frame
2023-1-21
fans59505ce8 Posted at 1-21 01:39
Could you please tell us that this issue also exists in other modes? Please also provide us with a video showing this issue for our further confirmation.
2023-1-21
