Hi! I am new here and hope that I post this in the right place!
I am trying to get the Android-FPVDemo running. I cloned the repository and tried to run the app on my phone. The App instantly crashes.
The app crashes when - it is connected to my computer / AndroidStudio
- to the DJI remote and
- not connected at all.
Phone: Samsung Galaxy S22 Ultra
Android: Android 13 Android Studio: Android Studio Dolphin | 2021.3.1 Patch 1 | Runtime version: 11.0.13+0-b1751.21-8125866 amd64 Drone: DJI Phantom 4 Pro V2
Logcat output: ---------------------------- PROCESS STARTED (15899) for package com.dji.FPVDemo ----------------------------
2023-01-18 11:08:24.818 15899-15899 nativeloader com.dji.FPVDemo D Configuring classloader-namespace for other apk /data/app/~~87ADPMzJhgZo_C6hP3qVbg==/com.dji.FPVDemo-p1u6VklFTAgKx13O_Ei8Ww==/base.apk. target_sdk_version=30, uses_libraries=, library_path=/data/app/~~87ADPMzJhgZo_C6hP3qVbg==/com.dji.FPVDemo-p1u6VklFTAgKx13O_Ei8Ww==/lib/arm64:/data/app/~~87ADPMzJhgZo_C6hP3qVbg==/com.dji.FPVDemo-p1u6VklFTAgKx13O_Ei8Ww==/base.apk!/lib/arm64-v8a, permitted_path=/data:/mnt/expand:/data/user/0/com.dji.FPVDemo
2023-01-18 11:08:24.818 15899-15899 nativeloader com.dji.FPVDemo D Extending system_exposed_libraries: libhumantracking.arcsoft.so:libPortraitDistortionCorrection.arcsoft.so:libPortraitDistortionCorrectionCali.arcsoft.so:libface_landmark.arcsoft.so:libFacialStickerEngine.arcsoft.so:libveengine.arcsoft.so:lib_pet_detection.arcsoft.so:libae_bracket_hdr.arcsoft.so:libhigh_res.arcsoft.so:libhybrid_high_dynamic_range.arcsoft.so:libimage_enhancement.arcsoft.so:liblow_light_hdr.arcsoft.so:libhigh_dynamic_range.arcsoft.so:libsuperresolution_raw.arcsoft.so:libuwsuperresolution.arcsoft.so:libFacialAttributeDetection.arcsoft.so:libBeauty_v4.camera.samsung.so:libexifa.camera.samsung.so:libjpega.camera.samsung.so:libOpenCv.camera.samsung.so:libVideoClassifier.camera.samsung.so:libtensorflowLite.dynamic_viewing.camera.samsung.so:libImageScreener.camera.samsung.so:libMyFilter.camera.samsung.so:libtflite2.myfilters.camera.samsung.so:libCandidSnapJNI.camera.samsung.so:libHIDTSnapJNI.camera.samsung.so:libSmartScan.camera.samsung.so:libRectify.camera.samsung.so:libDocRectifyWrapper.camera.sam
2023-01-18 11:08:24.826 15899-15899 GraphicsEnvironment com.dji.FPVDemo V ANGLE Developer option for 'com.dji.FPVDemo' set to: 'default'
2023-01-18 11:08:24.826 15899-15899 GraphicsEnvironment com.dji.FPVDemo V ANGLE GameManagerService for com.dji.FPVDemo: false
2023-01-18 11:08:24.826 15899-15899 GraphicsEnvironment com.dji.FPVDemo V App is not on the allowlist for updatable production driver.
2023-01-18 11:08:24.828 15899-15899 NetworkSecurityConfig com.dji.FPVDemo D No Network Security Config specified, using platform default
2023-01-18 11:08:24.833 15899-15899 NetworkSecurityConfig com.dji.FPVDemo D No Network Security Config specified, using platform default
2023-01-18 11:08:24.864 15899-15899 com.dji.FPVDemo com.dji.FPVDemo W Accessing hidden field Ldalvik/system/BaseDexClassLoader;->pathListdalvik/system/DexPathList; (unsupported, reflection, allowed)
2023-01-18 11:08:24.904 15899-15899 com.dji.FPVDemo com.dji.FPVDemo W Accessing hidden field Ldalvik/system/DexPathList;->dexElements:[Ldalvik/system/DexPathList$Element; (unsupported, reflection, allowed)
2023-01-18 11:08:24.933 15899-15899 AndroidRuntime com.dji.FPVDemo D Shutting down VM
2023-01-18 11:08:24.933 15899-15899 AndroidRuntime com.dji.FPVDemo E FATAL EXCEPTION: main
Process: com.dji.FPVDemo, PID: 15899
java.lang.RuntimeException: Unable to create application com.dji.FPVDemo.MApplication: java.lang.NullPointerException
at android.app.ActivityThread.handleBindApplication(ActivityThread.java:7603)
at android.app.ActivityThread.-$$Nest$mhandleBindApplication(Unknown Source:0)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2397)
at android.os.Handler.dispatchMessage(Handler.java:106)
at android.os.Looper.loopOnce(Looper.java:226)
at android.os.Looper.loop(Looper.java:313)
at android.app.ActivityThread.main(ActivityThread.java:8741)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:571)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1067)
Caused by: java.lang.NullPointerException
at java.util.Hashtable.put(Hashtable.java:461)
at android.graphics.Typeface.setFlipFonts(Typeface.java:1823)
at android.app.Application.onCreate(Application.java:275)
at com.dji.FPVDemo.MApplication.onCreate(:23)
at android.app.Instrumentation.callApplicationOnCreate(Instrumentation.java:1266)
at android.app.ActivityThread.handleBindApplication(ActivityThread.java:7598)
2023-01-18 11:08:24.949 15899-15899 Process com.dji.FPVDemo I Sending signal. PID: 15899 SIG: 9
---------------------------- PROCESS ENDED (15899) for package com.dji.FPVDemo ----------------------------
## End of Logcat output ##
I also had this problem when following your tutorial for the UXSDK Demo and creating the App from scratch.
Thanks!
