WernerD
Flight distance : 350837 ft
Austria
Regarding your question: Yes and no.
Yes, if you let go the controls, it stops. If you just pitch and yaw at speed zero, it holds it current position nicely.
The first BUT is the Motion Controller. With that you fly towards the point you are looking at through the camera. You cannot move sidewards, backwards, straight up/down while the camera remains. For example, flying in parallel to somebody but looking at him is not possible. Yes, I know the statement is technically not correct due to the head tracking feature of the goggles V2 but from a practical point of view you are very limited. To solve that, you need the FPV Controller. I will get one soon for sure.
What you can do with the Avata but not the regular drones is proximity flying. Flying 20cm close to something, following somebody from a few meters behind for a longer period of time.
In my opinion, the best DJI could do would be to enable the goggles V2 for the Mini 3 Pro. Then you would have the pros of the Mini 3 with the proximity flying options of FPV and for cinematic videos that would cover 95% of the use cases. Just imagine you look through the headset at a person skiing, all you do with the controller is control the speed. The drone does fly where you look at. That would be a very useful flight mode, easy to control!
At the moment however we do not even know if the goggles can be paired with the Mini 3 Pro ever, the head tracking is not for controlling the flight path, etc. |
